To use personal settings, you need to log in with personal authentication management. Managing Users
Available settingsThe settings listed below can be configured.
The language used on the touch panel display
Accessibility functions for users who have difficulty seeing or performing input operations on the touch panel display
Personal access point (personal SSID/network key)
<On>
<OK> to invert the screen colors and make text easier to read.
<On>
<OK> to enable you to zoom in or out on some screens by pinching out or in.
![]() This setting can be used when <Use Personal SSID and Network Key> is set to <On> in <Access Point Mode Settings>. <Access Point Mode Settings>
Only one mobile device may connect at a time when a personal SSID and network key are set.
Set the screen that is displayed when the machine startsIf the machine is configured so that users are required to log in when it starts up (Specifying When to Display the Login Screen), <Default Screen after Startup/Restoration> is displayed as an item in <Personal Settings>. The screen that is displayed after the machine starts up can be set for each user.
