Switching the Displayed Language
1A94-031
You can change the language and keyboard layout displayed on the touch panel display. If you switch languages frequently, it is convenient to use the <Switch Language/Keyboard> button. Follow the procedure below to show this button on the touch panel display.
Showing the <Switch Language/Keyboard> Button on the Touch Panel Display
1
Press .
2
Press <Preferences>  <Display Settings>.
3
Press <Display Switch Language/Keyboard Button>.
4
Press <On>  <OK>.
If you set it to <On>,  appears at the bottom of the touch panel display.
Switching the Language with the Button
1
Press  on the touch panel display.
2
Select a language from the list and press <OK>.
You can change the displayed language for each login user. Customizing the Screen Display Appearance and the Operational Conditions
imageRUNNER ADVANCE C355iF / C255iF
User's Guide
USRMA-1009-012017-02Copyright CANON INC. 2017
