Name
Canon imageRUNNER ADVANCE C355iF/C255iF
Type
Desktop
Color Supported
Full Color
Resolution for Reading
600 x 600 dpi
Resolution for Writing
2,400 dpi x 600 dpi (enhanced by smoothing technology)
Number of Tones
256
Acceptable Originals
Up to 8 1/4" x 11 3/4" (210 x 297 mm): Sheet, book, three dimensional objects (up to 4.4 lb (2 kg))
Copy Size/Copy Paper
Paper Sizes
Max: 8 1/2" x 14" (216 x 355.6 mm)*1
Min: 3 7/8" x 5 7/8" (98 x 148 mm)
Margin
Top: 3/16" (4.0 mm)
Left and Right: 3/16" (4.2 mm) (LTR)
Bottom: 1/8" (2.5 mm)
Paper Weight
Paper Drawer: 16 lb bond to 60 lb cover (60 to 163 g/m²)
Multi-Purpose Tray: 16 lb bond to 80 lb cover (60 to 220 g/m²)
Paper Type
Warm-Up Time
After Powering ON
imageRUNNER ADVANCE C355iF: 30 seconds*2
imageRUNNER ADVANCE C255iF: 34 seconds*2
Returning from the Sleep mode
10 seconds*3
First Copy Time
Full Color: 6.9 seconds
Black-and-White: 5.1 seconds
Full Color: 9.4 seconds
Black-and-White: 6.9 seconds
Copy Speed*4
(Plain LTR, 100%)
Full Color: 36 sheets/minute
Black-and-White: 36 sheets/minute
Full Color: 26 sheets/minute
Black-and-White: 26 sheets/minute
Magnification
Regular Paper Size
Same Ratio: Direct±0.5%
Enlargement: 129%, 200%, 400%
Reduction: 78%, 64%, 50%, 25%
Zoom
25% to 400% (in 1% increments)
Paper Feeding System/Capacity
Paper Drawer
550 sheets (20 lb bond (80 g/m²))/640 sheets (17 lb bond (64 g/m²)) x 1
Multi-Purpose Tray
100 sheets (20 lb bond (80 g/m²))/120 sheets (17 lb bond (64 g/m²)) x 1
Multiple Copies
999 sheets
Power Source
120 V AC, 60 Hz, 6.9 A
Power Consumption
Maximum Power Consumption
1.5 kW or less
When the machine is in the Sleep mode
0.8 W or less (When <Sleep Mode Energy Use> is set to <Low>)
When the main power switch is turned OFF
When <Quick Startup Settings for Main Power> is set to <Off>: 0.1 kW or less
When <Quick Startup Settings for Main Power> is set to <On>: 0.5 kW or less
* The values may differ depending on the environmental conditions or use conditions.
Dimensions
(W x D x H)
20 1/8" x 25 5/8" x 25 1/8" (511 x 651 x 639 mm)
Weight
(Toner bottle included)
Approximately 108.0 lb (49 kg)
Maximum Occupancy Space
(W x D)
33 1/2" x 25 5/8" (852 × 651 mm) (when the multi-purpose tray is extended)
Installation Space
(W x D)
Main unit only
![]() With Staple Finisher-Z
Memory Capacity
RAM
Main CPU: 2 GB
Image processing CPU: 1 GB
HDD
250 GB
Inner Tray Capacity
250 sheets (20 lb bond (80 g/m²))
