Paper Sizes
Paper Drawer 1
Paper Drawer 2, 3, or 4
Multi-Purpose Tray
LGL
LTR
STMT
EXEC
A4
A5
B5
16K
Custom Size
*1 |
*1 |
*2 |
Yougatanaga 3
*3 |
Nagagata 3
*3 |
No.10 (COM10)
*3 |
Monarch
*3 |
DL
*3 |
ISO-C5
*1 You can use custom size settings ranging from 3 7/8" x 7 1/2" to 8 1/2" x 14" (98 x 190.5 mm to 216 x 355.6 mm).
*2 You can use custom size settings ranging from 3 7/8" x 5 7/8" to 8 1/2" x 14" (98 x 148 mm to 216 x 355.6 mm).
*3 The Envelope Feeder Attachment is required to load envelopes.
Paper Type
Paper Drawer 1
Multi-Purpose Tray
Thin 1
16 lb bond (60 to 63 g/m2)
Plain 1
17 to 20 lb bond (64 to 75 g/m2)
Plain 2
21 to 24 lb bond (76 to 90 g/m2)
Plain 3
25 to 28 lb bond (91 to 105 g/m2)
Heavy 1
29 to 34 lb bond (106 to 128 g/m2)
Heavy 2
35 to 40 lb bond (129 to 150 g/m2)
Heavy 3
56 to 60 lb cover (151 to 163 g/m2)
Heavy 4
61 to 66 lb cover (164 to 180 g/m2)
Heavy 5
67 to 80 lb cover (181 to 220 g/m2)
Recycled 1*1
Recycled 2*1
Recycled 3*1
Color
Pre-punched
Transparency*2
32 lb bond to 80 lb cover (121 to 220 g/m2)
Labels
31 lb bond to 68 lb cover (118 to 185 g/m2)
Bond
Envelope
22 to 28 lb bond (83 to 105 g/m2)
*1 You can use 100% recycled paper.
*2 Use only LTR or A4 transparencies specially made for this machine.
Paper size:
LGL, LTR, STMT, EXEC, A4, A5, B5, 16K and Custom Size (5 1/2" x 8 1/4" to 8 1/2" x 14" (139.7 x 210.0 mm to 216.0 x 355.6 mm))*1
Paper weight:
16 lb bond to 60 lb cover (60 to 163 g/m2)
*1 Heavy 4, Heavy 5, Transparency, Labels, and Envelope are not available for 2-sided copying.
Do not use the following types of paperDoing so may cause a paper jam or other printing problems.
Wrinkled or creased paper
Curled or rolled paper
Torn paper
Damp paper
Very thin paper
Thin straw paper
Paper printed by a thermal transfer printer
The reverse side of paper which has been printed by a thermal transfer printer
Highly textured paper
Glossy paper
When using paperOnly use paper that has fully acclimatized to the environment in which this machine is installed. Using paper that has been stored under different temperature or humidity may cause paper jams or result in poor print quality.
Paper handling and storageWe recommend using the paper immediately after opening the package. Rewrap any remaining paper in its original package, and store it on a flat surface.
Keep the paper wrapped in its original package to protect the paper from moisture or dryness.
Do not store the paper in such a way that may cause it to curl or fold.
Do not store the paper vertically or stack too much paper.
Do not store the paper in direct sunlight, or in a place subject to high humidity, dryness, or drastic changes in temperature or humidity.
When printing on paper that has absorbed moistureSteam may emit from the paper output area, or water droplets may form around the paper output area. There is nothing unusual about any of these occurrences, which occur when the heat generated from fixing toner on the paper causes moisture in the paper to evaporate (most likely to occur at low room temperatures).
