Paper drawer
Lower-right cover
If paper runs out and printing is stopped when you are printing with the staple setting, do not remove the output sheets that are waiting to be stapled. (Printing and stapling resume after you clear the paper jam.)
Only LTR paper can be loaded in the High Capacity Cassette Feeding Unit-A1.
Load the paper stack with the print side face up, and against the right side wall of the paper drawer.
Move the paper guide to the left edge.
Load the paper stack against the left side wall of the paper drawer.
Confirm whether the paper on the left side has been correctly loaded.
Do not exceed the load limit line when loading paperMake sure that the paper stack does not exceed the load limit line (
). Loading too much paper can cause paper jams. |
If you use paper with a logo mark, pay attention to the orientation when loading it in the paper source. Loading Preprinted Paper
Do not load the following types of paper into the High Capacity Cassette Feeding Unit-A1. Doing so may cause a paper jam.
Severely curled or wrinkled paper/thin straw paper/heavy paper (more than 140 lb index (256 g/m2))/paper which has been printed on using a thermal transfer printer/the reverse side of paper which has been printed on using a thermal transfer printer/transparency /coated paper/Labels /tracing paper/tab paper. Paper which is curled must be straightened out before loading it into the paper deck unit.
Do not load paper into the High Capacity Cassette Feeding Unit-A1 that has been previously copied onto, as this may result in a malfunction or damage to the machine. Always use the multi-purpose tray to feed paper when you want to print onto the back of a sheet of paper (2nd side of 2-Sided copy).
You will not be able to make copies or print if the paper drawer is not completely pushed into the paper deck unit.
If problems occur when printing, try turning the paper stack over, and reload it.
