If the machine is in the Sleep mode (the touch panel is not displayed, and only
![]() ![]() If the Multi-drawer Paper Deck-A1 is attached, the multi-purpose tray cannot be used.
The following paper sizes can be loaded into the Multi-drawer Paper Deck-A1:
13" x 19", 12" x 18", 12 5/8" x 17 11/16", 11" x 17", LGL, LTR, LTRR, STMTR, EXEC, and custom size (5 1/2" x 7 1/8" to 13" x 19 1/4" (139.7 mm x 182 mm to 330.2 mm x 487.7 mm))
To detect when multiple papers are fed with the Multi-drawer Paper Deck-A1, the Paper Deck Double Feeding Detection Kit-A1 is required.
Front Cover (Buffer Pass)
Open this cover to remove jammed paper. (See "Front Cover of the Multi-drawer Paper Deck-A1 (Optional).")
Open Button
Press to open the paper deck when you need to load paper or check for a paper jam.
Paper Deck
Up to 2,000 sheets of paper (20 lb bond (80 g/m2)) or 2,200 sheets of paper (17 lb bond (64 g/m2)) each can be loaded into the upper, middle, and lower decks
