Specifying Settings for the Display Screen
You can change the size and encoding of characters within a Web page.
Changing the Text Size
You can change the text size of a Web page.
Press [Web Access].
Press [Menu].
Press [Text Size].
4.
Select the text size → press [OK].
You can select [Small], [Medium], or [Large]. The default text size is 'Medium'.
Even if you change the text size setting, the change may not be reflected for some Web pages.
Changing the Character Encoding
A Web page includes information about the character encoding (unique numbers that correspond to each character and symbol) of the display language. Character encoding varies with each Web page.
Press [Web Access].
Press [Menu].
Press [Encode].
If the characters of a Web page are unreadable, select an appropriate character code to display the characters correctly.
4.
Select the character code → press [OK].
There may be cases in which the selected settings for the character code are not properly reflected even if you press [Encode] again after you specify the settings.
Changing the Display Magnification
You can adjust the display magnification for the screen.
The display magnification can be set from 50% to 200% in 25% increments.
Press [Web Access].
Press [Menu].
Press [Zoom].
4.
Select the zoom size → press [OK].
If multiple windows are open, the settings are applied only to the window that is currently displayed on top.
» Web Access » Specifying Settings for the Display Screen
08JK-1CH
