Category Top
Overview of This Function
Advanced Box/Network Settings
Mail Box
Advanced Box
Network
Memory Media
Flow of Operations for Accessing Stored Files
Printing Files Stored in a Mail Box
Printing Files Stored in the Advanced Box
Printing Files Stored on the Network
Printing Files Stored in Memory Media
Canceling a Job While Printing
Reserving Jobs
Arranging Files Stored in a Mail Box
Checking File Information
Previewing a File
Operations for Files Stored in a Mail Box
Printing Lists
Arranging Files and Folders Stored in the Advanced Box
Checking Detailed Information of the Advanced Box
Personal Space Operations
Folder Operations
Previewing a File
Operations for Files Stored in a Folder
Arranging Files and Folders Stored on the Network
Checking Storage Information
Folder Operations
Previewing a File
File Operations
Arranging Files and Folders Stored in Memory Media
Checking the Detailed Information for Memory Media
Folder Operations
Previewing a File
File Operations
Printing a Sample
Storing Print Settings
Adjusting Density During Printing
Merging Files When Printing
Favorite Settings
Storing Favorite Settings
Recalling/Deleting Favorite Settings
Changing Color Modes
Paper Selection
Collating Prints
Two-Sided Printing
Convenient Modes for Printing
Adding a Cover
Inserting Sheets
Booklet Mode
Job Separator
Shifting the Original Image Using the Numeric Keys
Adding a Secure Watermark
Document Scan Lock
Document Scan Lock (TL Code)
Document Scan Lock (QR Code)
Superimpose Image
Gutter
Page Numbering
Copy Set Numbering
Watermark Printing
Date Printing
Adjusting the Color
Adjust One-Touch Color
Print on Tab
Adjusting the Print Resolution
Printing with Halftones
Adjusting Printing to Fit the Paper Size
Enlarging the Print Area
Printing Files with Multiple Pages on One Page (N On 1)
Printing Comments
Printing Password Protected PDF Files
Enlarging and Reducing Prints
Setting the Print Orientation
Setting the Print Position
Sending a File
Unavailable Combination of Functions
Top » Access Stored Files » Page Numbering
Page Numbering
08JK-191
This mode enables you to print page numbers, numbers with hyphens, and chapter numbers etc. on outputs.
This mode can be used only for printing a file stored in a mail box.
Press [Access Stored Files] → [Mail Box].
Select the desired Mail Box → select the desired file → press [Print].
Press [Change Print Settings].
4.
Press [Options] → [Page Numbering].
5.
Select the type of page number.
6.
Set the image orientation and print position.
Orientation:
[Upright Image]:
Prints the image upright on the paper.
[Sideways Image]:
Prints the image sideways on the paper.
Upright Image
Sideways Image
If you set any two of [Copy Set Numbering], [Watermark], or [Print Date] to print in the same position, a confirmation message appears when you press (Start).
You can press [Set Details] to adjust the printing position and set the printing position for the back side when performing two-sided printing.
To adjust the printing position, press [X] or [Y] → adjust the printing position with [-] or [+] → press [OK].
To set the printing position for the back side when performing two-sided printing, select [Opposite to Front Side] or [Same as Front Side] → press [OK].
7.
Specify the print settings for the page numbers.
Press the <Color> drop-down list → select the color of the page numbers.
Press the <Size> drop-down list → select the size of the page numbers.
Enter the starting number using - (numeric keys).
8.
To specify detailed printing settings, press [Set Details].
If you do not want to specify other settings, proceed to step 9.
Specifying the number of digits to be printed:
Adding text:
Counting inserted sheets:
Press [No. of Digits].
Press [-] or [+] to enter the number of digits to display → press [OK].
You can specify between '2' and '5' digits.
Example:
If the page number is 10, and the number of digits is 2: 10 → 10
If the page number is 10, and the number of digits is 5: 10 → 00010
If the specified number of digits is less than the number of digits of the actual page number, the setting is invalid.
Adding text:
Press [Add Characters].
Press [Enter].
Enter the text → press [OK].
You can also select text that has been registered in [Register Characters for Page No./Watermark]. (See "Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks.")
Select the printing position for the text to add → press [OK] → [OK].
Press [Inserted Sheets].
Press [Count] → [OK] → [OK].
Counts all sheet insertions, chapter pages, and back covers inserted after the first page. However, chapter numbers and page numbers are only printed onto the main document pages.
If you press [Do Not Count], the machine does not count any sheets, chapter pages, or back covers inserted after the first page. Chapter numbers and page numbers are only printed onto the main document pages.
9.
Press [OK] → [Close].
Printing performance may not be optimal, depending on the file content and combination of settings.
If you use [Page Numbering] with [Add Cover], [Insert Sheets], or [Job Separator], numbers will not be printed on the inserted pages.
The Superimpose Image mode cannot be used with files including images with resolutions of less than 600 x 600 dpi.
If you select [Numbered Chapters] in combination with the Sheet Insertion or Job Separator mode, the chapter numbers are counted at the following times:
After each chapter page is inserted
After each sheet insertion is inserted
