Top » Hold » Canceling a Job
Canceling a Job
08JK-1AR
The printing of a file stored in the Hold Que can be canceled from the touch panel display and Status Monitor/Cancel screen.
Canceling a Job Using the Touch Panel Display
Press [Hold].
Select the job that you want to cancel from the Print Job List screen → press [Cancel].
The job is canceled.
Using the Status Monitor/Cancel Screen
Press (Status Monitor/Cancel).
Press [Copy/Print].
Press [Job Status] → select [Print] from the drop-down list.
You cannot select multiple jobs and cancel them all at once. Select and cancel one job at a time.
4.
Select the job that you want to cancel → press [Cancel].
5.
Press [Yes].
The canceled job appears as <NG> (No Good) on the Log screen.
6.
Press [OK].
The display returns to the Print Job List screen.
