e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand All
Collapse All
Category Top
Overview of This Function
Processing Received Files
Memory RX Inbox
Memory RX Inbox
Receiving Files Through Fax or I-Fax
Checking the Detailed Information for/Deleting a File in the Memory RX Inbox
Printing a File in the Memory RX Inbox
Sending a File in the Memory RX Inbox
Divided Data RX Inbox
Confidential Fax Inbox
Checking the Detailed Information for/Deleting a File in a Confidential Fax Inbox
Printing a File in a Confidential Fax Inbox
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Fax/I-Fax Inbox
Memory RX Inbox
Memory RX Inbox
07SE-140
You can select either the Memory RX Inbox or Divided Data RX Inbox from the Memory RX Inbox screen.
Memory RX Inbox
Back to Top
