: Only the administrator can change the settings.|
Settings/Registration
System Manager/System Administrator (Administrator)
Network Administrator (NetworkAdmin)
Device Administrator (DeviceAdmin)
[Paper Settings]
[Paper Type Management Settings]
[Display Settings]
[Default Screen after Startup/Restoration]
[Display Fax Function]
[Store Location Display Settings]
[ID/User Name Display On/Off]
[Display Remaining Toner Error Message]
[Timer/Energy Settings]
[Date/Time Settings]
[Time Format]
[Quick Startup Settings for Main Power]
[Restrict Auto Reset Time]
[Network]
[Confirm Network Connection Set. Changes]
[TCP/IP Settings]
[IPv4 Settings]
[IPv6 Settings]
[DNS Settings]
[WINS Settings]
[LPD Print Settings]
[RAW Print Settings]
[SNTP Settings]
[FTP Print Settings]
[WSD Settings]
[Use FTP PASV Mode]
[IPP Print Settings]
[Multicast Discovery Settings]
[Use HTTP]
[SSL Settings]
[Proxy Settings]
[Confirm Dept. ID PIN]
[IPSec Settings]
[NetWare Settings]
[AppleTalk Settings]
[SMB Server Settings]
[SNMP Settings]
[Dedicated Port Settings]
[Use Spool Function]
[Startup Settings]
[Ethernet Driver Settings]
[IEEE802.1X Settings]
[Firewall Settings]
[IPv4 Address Filter]
[IPv6 Address Filter]
[MAC Address Filter]
[IP Address Block Log]
[External Interface]
[USB Settings]
[Common]
[Print Settings]
[Copy Set Numbering Option Settings]
[Secure Watermark/Document Scan Lock]*
[Scan Settings]
[Auto Online]
[Auto Offline]
[Generate File]
[Rights Management Server Settings]
[Document Scan Lock Operational Settings]
[Set Authentication Method]
[Copy]
[Select Color Settings for Copy]
[Printer]
[Restrict Printer Jobs]
[PDL Selection (Plug-n-Play)]
[Send]
[Common Settings]
[TX Report]
[Report with TX Image]
[Confirm SSL Certificate for WebDAV TX]
[Limit New Destination]
[Always Add Device Signature to Send]
[Limit E-Mail to Send to Myself]
[Restrict File TX to Personal Folder]
[Personal Folder Specification Method]
[Restrict Resending from Log]
[E-Mail/I-Fax Settings]
[Communication Settings]
[Confirm SSL Certificate for SMTP TX]
[Confirm SSL Certificate for POP RX]
[Maximum Data Size for Sending]
[Set Data Size for Send Warning]
[Default Subject]
[Specify Authentication User Dest. to Reply]
[Set Authentication User Destination to Sender]
[Allow Unregistered Users to Send E-Mail]
[Full Mode TX Timeout]
[Print MDN/DSN upon Receipt]
[Use Send via Server]
[Allow MDN Not via Server]
[Restrict TX Destination Domain]
[Autocomplete for Entering E-Mail Addresses]
[Fax Settings]
[Use Auth. User Name as Sender Name]
[Fax TX Report]
[Set Line]
[TX Start Speed]
[PIN Code Access]
[Confirm Entered Fax Number]
[Allow Fax Driver TX]
[Confirm Before Sending When Fax Dest. Incl.]
[Restrict Seq. Broadcast When Fax Dest. Incl.]
[Remote Fax TX Settings]
[Receive/Forward]
[Common Settings]
[Interrupt and Print RX Jobs]
[Handle Files with Forwarding Errors]
[Forwarding Settings]
[Set Fax/I-Fax Inbox]
[Memory RX Inbox PIN]
[Use Fax Memory Lock]
[Use I-Fax Memory Lock]
[Memory Lock Start Time]
[Memory Lock End Time]
[Divided Data RX Timeout]
[Always Send Notice for RX Errors]
[Fax Settings]
[RX Start Speed]
[RX Password]
[Store/Access Files]
[Common Settings]
[Access Stored Files Settings]
[Limit Box PIN to 7 Digits/Restrict Access]
[Network Settings]
[Protocol for External Reference]
[Confirm SSL Certificate for Network Access]
[Memory Media Settings]
[Secure Print]
[Simple Authentication Settings]
[Only Allow Encrypted Print Jobs]
*1
The setting names may differ depending on the optional products available for use.
[Address Book PIN]
[Manage Address Book Access Numbers]
[Include Pswd. When Exporting Address Book]
[Register LDAP Server]
[Auto Search When Using LDAP Server]
[Change Default LDAP Search Conditions]
[Register/Edit LDAP Search Conditions]
[Acquire Remote Address Book]
[User Management]
[System Manager Information Settings]
[Department ID Management]
[Device Management]
[Device Information Settings]
[Device Information Delivery Settings]
[Limited Functions Mode]
[Certificate Settings]
[Display Job Status Before Authentication]
[Display Log]
[Save Audit Log]
[Store Key Operation Log]
[Format Encryption Method to FIPS 140-2]
[License/Other]
[Register License]
[MEAP Settings]
[Remote UI]
[Delete Message Board Contents]
[Remote Operation Settings]
[Use ACCESS MANAGEMENT SYSTEM]
[Register/Update Software]
[Data Management]
[Delete Existing Data Settings]
[Initialize All Data/Settings]
[TPM Settings]
For information on the types of administrators, see "Administrator Settings."
All users can set the settings in [Adjustment/Maintenance] (Settings/Registration).
