Copy Set Numbering Options
You can specify the detailed settings of the Copy Set Numbering mode. For more information on the Copy Set Numbering mode, see
"Copy Set Numbering" (Copy).
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Print Settings].
Press [Copy Set Numbering Option Settings] → [On] for <Number Option> → specify each setting.
If you do not want to specify copy set numbering option settings, press [Off].
<Number Option>
[On]:
[Full Surface] and [Numbers in 5 Locations] are grayed out, and cannot be selected.
You can select [10.5 pt], [12.0 pt], or [14.0 pt] for the size of the text.
[Off]:
You can select [Full Surface] or [Numbers in 5 Locations].
You can select [12.0 pt], [24.0 pt], or [36.0 pt] for the size of the text.
To Print the ID/User Name:
Press [On] for <ID/User Name> → [Next].
Select the way you would like to align the selected or entered characters on the page → press [OK].
Press [On] for <Date> → [Next].
Select the date format → press [Next].
To Print User-Defined Text:
Press [On] for <Text> → [Next] → [Enter].
Enter the text to print → press [OK] → [Next].
If you have registered characters in [Register Characters for Page No./Watermark] in [Function Settings] (Settings/Registration), you can select the characters from the list.
