Key Pair and Server Certificate Settings for Encrypted SSL Communication
07SE-1YR
A key pair and server certificate are required for performing SSL encrypted communication with the following.
This section describes how to specify the key pair and server certificate settings from the control panel of the machine.
This section also describes how to register/edit a CA certificate file which is required to check the legitimacy of the certificate, and how to verify the validity of the certificate using Certificate Revocation List (CRL).
