Category Top
Optional Equipment and System Requirements
Printing or Sending a Fax from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE802.1X Authentication Settings
Selecting the IEEE802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Startup Time Settings
Setting Up a Computer for Printing/Sending a Fax
Printer Connection Method (LPD/Raw)
Windows XP/Server 2003/Server 2008/Vista/7/Server 2008 R2
Mac OS X 10.4.9 or Later
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
NetWare Network Setup Procedures
NetWare Print Service Settings
Setup Using NetWare Administrator or PCONSOLE
Protocol Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
AppleTalk Network Setup Procedures
Protocol Settings
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2
Top » Network » Data Sending/File Sharing Problems and Remedies
07SE-1RC
This section describes how to resolve data sending/file sharing problems.
Unable to Send Data/Share Files (FTP)
Cause 1
The FTP server is not set correctly.
Remedy
Execute the following command to check the server status. (If you are using Windows, perform these from the command prompt.)
Example using UNIX, where the FTP server has the IP address:
U:>ftp 192.168.1.195*Connect to server
Connected to 192.168.37.195.
220 canmfs FTP server (UNIX(r) System V Release 4.0) ready.
User (192.168.37.195:(none)): user_name*User login
331 Password required for user_name.
Password:*Enter password
230 User user_name logged in.
ftp>cd /export/share*Move to data destination directory
250 CWD command successful.
ftp> bin*Set data transfer type (binary)
200 Type set to I.
ftp> put sample.tif*Set transfer file name for verification
ftp> by*Cut off server connection
221 Goodbye
If the above are confirmed and file sharing still does not operate normally, consult the administrator for the network you are using.
Cause 2
The machine's address [User Name] setting contains one or more spaces after the user name.
Remedy
Ensure that the machine's address [User Name] setting does not contain spaces after the user name.
Cause 3
The machine was turned OFF while sending data to the FTP server, and when the machine was turned back ON, it attempted to resend the data. (If a Windows XP/Server 2003/Vista/Server 2008/7/Server 2008 R2 FTP server is being used.)
Remedy
If power to the machine is turned OFF while data is being sent to the FTP server, the FTP server may hold the data in a writing-in-progress state. Therefore, this data cannot be overwritten even when the machine reconnects and sends the same data again. Stop the FTP server temporarily and delete the held data, so it can be sent again.
Cause 4
An error message appears on the touch panel display of the machine.
Remedy
After confirming the error message, see "List of Error Messages" and perform the necessary operations according to the error message displayed.
Unable to Send Data/Share Files (Windows and Samba File Sharing)
Cause 1
File sharing settings for the shared folder are incorrect.
Remedy
Check the following:
Check that the computer you want to share is listed in [Network]/[My Network Places] on the computer you are using. (You can also check that the computer you want to share is on the network using the quick search box function in [Network], or [Find] on the [Start] menu.)
If the computer you want to share is listed, double-click its icon to see whether the shared name of the folder you want to share is listed.
If the shared name does not appear, see "Setting Up a Computer as a File Server," and then check the shared folder settings.
Cause 2
Remedy
