Category Top
Overview of This Function
Overview of Login Services
Login Screens
SSO-H (Single Sign-On H)
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Menu for Administrators
Registering/Editing User Data for LDAP Server Authentication
Setting the SSO-H
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Other Trouble
Top » MEAP » Troubleshooting » Trouble That May Occur When the Windows Server Firewall Is Set
07SE-1XH
This section explains the various problems that may occur when a firewall is set, along with possible causes and remedies.
Symptom: Service information fails to be retrieved when automatically retrieving domain information.
Cause
Communication with the DNS server is blocked due to firewall settings.
Remedy
Unblock port 53 (the default port) for the UDP protocol and TCP protocol. The DNS server normally uses port 53 to perform communications with the UDP protocol, but as data over a certain size may be processed using the TCP protocol, unblock port 53 for both the TCP protocol and UDP protocol.
Symptom: Active Directory Authentication has failed. (The <Authentication server not operating.> error message appears.)
Cause
Active Directory Authentication is blocked due to firewall settings.
Remedy
Unblock port 88 (the default port) for the UDP protocol and TCP protocol. Active Directory Authentication normally uses port 88 to perform communications with the UDP protocol, but as data over a certain size may be processed using the TCP protocol, unblock port 88 for both the TCP protocol and UDP protocol.
Symptom: User authentication has failed.
Cause
Communication for LDAP searches is blocked due to the firewall settings.
Remedy
Unblock port 389 (the default port) for the TCP protocol. User data is retrieved from Active Directory using LDAP searches. By default, LDAP searches are performed using the TCP protocol with port 389. Therefore, unblock port 389 for the TCP protocol. (If the port number used for the TCP protocol has been changed, unblock the port number used by the TCP protocol.)
