You can change the login method for SMS; to use the shared password for SMS, or the user name and password used to login to the machine.
Click [System Application Management].
Click [Start] or [Stop] for the application that you want to start/stop.
If you are logged in using the password for SMS:
If you are logged in using the user name and password:
[Application Name]
Displays the name of the application.
[Date Installed]
Displays the date on which the application was installed.
[Application ID]
Displays a unique application ID.
[Status]
Displays the status of the application.
[Start]: Stop button is displayed.
[Stop]: Start button is displayed.
You can [Start] both Password Authentication and Remote Login Service Authentication, but cannot [Stop] both. (At least one is set to [Start].)
The available settings may differ, depending on the status when you logged in.
If you logged in using the password for SMS: You can start/stop the user name and password login service (Remote Login Service Authentication).
If you logged in using the user name and password for the machine: You can start/stop the SMS password login service (Password Authentication).
» MEAP » Changing the Login Method for SMS
07SE-1W8
