Default Authentication (Department ID Management) is set to a usable state as the default. If you want to use SSO-H, set [Department ID Management] to 'Off' before changing the login service. For more information on Department ID Management settings, see "Specifying Department ID Management."
Changes to the login service settings are enabled after the machine is restarted. For instructions on turning ON/OFF the machine, see "Main Power and Energy Saver Key."
If you have logged in with the user name and password of the machine, the login service will not be displayed on the top of screen. To change the login service, log in with the SMS password.
To set Local Device Authentication, the registered information in Local Device Authentication and the registered user data (Department ID and PIN) in Department ID Management of the machine have to match.
To use Local Device Authentication and Department ID Management at the same time, update the Local Device Authentication user data (Department ID and corresponding PIN) and set [Department ID Management] to 'On', after switching the login service to SSO-H.
If 'Server Authentication' or 'Server Authentication + Local Device Authentication' of SSO-H is set, you cannot use the control card reader.
If you are using the SSO-H Active Directory Authentication, you must match the time settings of the server with Active Directory installed and the time settings of the machine (and the computer to log in with).
If SSO-H is set as the login service, it takes time to access the Remote UI.
