WARNING |
Do not connect or disconnect the power cord with wet hands, as this may result in electrical shock.
You can change the default display that appears after the machine is turned ON from [Default Screen after Startup/Restoration] on the Settings/Registration screen. (See "Default Screen after Startup/Restoration.")
If this machine is connected to a powered off Macintosh computer by USB cable, the computer may turn on automatically when this machine does. In this case, disconnect the USB cable from the machine. You may also be able to solve this problem by using a USB hub between the machine and the computer.
The response of the buttons and keys may not be optimal immediately after you turn ON the main power of the machine.
If you set [Quick Startup Settings for Main Power] to 'On' in [Preferences] (Settings/Registration), the tone sounds when turning ON the main power of the machine. (Depending on the situations, the machine does not startup quickly and the tone does not sound.)
If the machine takes longer to startup than usual, see "Quick Startup Settings."
If you are using Department ID Management with the Copy Card Reader-F1, see "Copy Card Reader-F1."
If you are using Department ID Management, see "Entering the Department ID and PIN."
If you are using SSO-H, see "Login Service."
(Energy Saver) to cancel the Sleep mode.
" side.|
Do not turn the main power OFF while using the Fax/I-Fax function. Sending or receiving I-fax or fax documents cannot be done when the main power is turned OFF.
The machine may take some time to completely shutdown. Do not unplug the power cord until the Main Power indicator of the machine is off.
If the main power is turned OFF during scanning or printing, a paper jam may occur.
If you set [Quick Startup Settings for Main Power] to 'On' in [Preferences] (Settings/Registration), the tone sounds when turning OFF the main power of the machine. (Depending on the situations, the machine does not startup quickly and the tone does not sound.)
If you want to turn OFF the main power and then back ON again, wait for at least 10 seconds after the Main Power indicator is turned off before turning ON the main power.
The machine can receive and print documents from a personal computer when it is in the Sleep mode. I-fax and fax documents can also be received while the machine is in the Sleep mode.
You can shut down the machine from the Remote UI using the Remote Shutdown mode. For more information, see "Shutting Down the Machine from the Remote UI."
