Category Top
Overview of This Function
Overview of Login Services
Login Screens
SSO-H (Single Sign-On H)
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Menu for Administrators
Registering/Editing User Data for LDAP Server Authentication
Setting the SSO-H
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Other Trouble
Top » MEAP » Managing Applications » Setting Application Authentication Information
07SE-1W0
To perform an operation from an application that does not require to be operated from the machine, you must specify the settings for application authentication information in advance.
If you change the login application, confirm the authentication information. It may be necessary to re-enter the authentication information.
Click [MEAP Application Management].
Click the name of the application to set authentication information for.
Click [Authentication Information Settings].
4.
Enter the authentication information.
If Default Authentication (Department ID Management) is set as the login service:
If SSO-H is set as the login service:
Enter the Department ID and PIN.
Enter the user name and password → select the login destination.
5.
Click [Update].
The message <Authentication information is set> appears if the authentication information is set successfully. If an error occurs when setting the authentication information, an error message appears.
You can click [Delete] to delete the authentication information settings.
