(Settings/Registration).
[Space]:
Press to insert a space between the area code and the local fax number.
Use to insert a country code. Press [+] after the country code, before the fax number.
Press to move the position of the cursor.
[Backspace]:
Press to delete the last number entered.
Depending on the fax board installed, the lines that you can register the unit's telephone number and name for vary as shown below:
If the Super G3 FAX Board is installed: Line 1
If the Super G3 FAX Board and Super G3 2nd Line Fax Board are installed: Line 1, Line 2
You can set to display/print the Sender Name instead of the name stored as the unit's name from [Sender Name (TTI)] in [Options]. (See "Selecting the Sender's Name When Sending a Fax.")
The unit's name can be printed on the received documents as the Sender Name.
Depending on the fax board installed, the lines that you can register the telephone line type for vary as shown below:
