Options Attached
Default Setting
Tray A/B/C
Inner 2Way Tray-F1
Tray A: 1 Copy, 1 Access Stored Files, 1 Printer, 2 Receive, 2 Fax*1, 2 Other
Tray B: 2 Copy, 2 Access Stored Files, 2 Printer, 1 Receive, 1 Fax*1, 1 Other
Copy Tray-J1
Inner 2Way Tray-F1 and Copy Tray-J1
Tray C: 1 Receive, 1 Fax*1, 1 Other |
Inner Finisher-F1 and Inner Finisher Additional Tray-A1
Inner Finisher-F1 and Copy Tray-J1
Inner Finisher-F1, Inner Finisher Additional Tray-A1, and Copy Tray-J1
Tray A: 1 Copy, 1 Access Stored Files. 1 Printer
Tray B: 2 Copy, 2 Access Stored Files, 2 Printer Tray C: 1 Receive, 1 Fax*1, 1 Other |
Staple Finisher-M1 and Buffer Pass Unit-K1
Booklet Finisher-M1 and Buffer Pass Unit-K1
(Settings/Registration).
Details of each item are shown below:
[Tray A]:
Tray A moves closer to the output area.
[Tray B]:
Tray B moves closer to the output area.
[Off]:
The tray home position is not set. The output tray stops at the position it is in when printing finishes.
If a certain tray reaches its stacking limit, the machine automatically uses another tray that is designated for the same function. However, it is recommended that you only designate one tray for fax/I-fax documents to prevent them from getting lost.
If the Inner Finisher-F1 and Copy Tray-J1 are attached and the Staple mode is set, the sheets are output to Tray A, regardless of the Tray Designation settings.
If the Copy Tray-J1 is attached and you select any of the following paper types, the sheets are output to trays other than the Copy Tray-J1, even if the Copy Tray-J1 is specified as the destination: nonstandard, envelopes, heavy paper, transparencies, labels, or tracing paper.
You can designate an output tray for multiple functions.
The priority order of the output destinations is determined by the order of the selected output trays. The priority is displayed as "1," "2," and "3."
