Cascade Copy Communication Timeout
08KE-09U
You can set to cancel cascade copying when there is no response from the cascade copy printer for a certain period of time. You can set the time from 5 seconds to 30 seconds, in 1 second increments.
This mode can be set when the Copy function is available for use. For information on the optional products required to use the Copy function, see
"Optional Products Required for Each Function."
Press
(Settings/Registration).
Press [Function Settings] → [Copy] → [Cascade Copy Communication Timeout].
Set the time using [-] or [+] → press [OK].
Jobs that timeout (jobs that are not received by the cascade copy printer) are deleted.
