Copying with the Printed Image Mode
08KE-09R
You can enable the Printed Image mode. If this mode is set to 'On', you can select [Printed Image] or [Photo Printout] for the image quality when copying.
This mode can be set when the Copy function is available for use. For information on the optional products required to use the Copy function, see
"Optional Products Required for Each Function."
Press
(Settings/Registration).
Press [Function Settings] → [Copy] → [Photo Printout Mode].
Press [On] → [OK].
Select [Off] if you do not want to use the Printed Image mode.
