Registering/Editing LDAP Search Attributes
Press [Set Destination] → [Register/Edit LDAP Search Conditions].
Register/edit the LDAP search attributes as required.
To register a search attribute:
To edit a search attribute:
To delete a search attribute:
Press [Not Reg'd 1] or [Not Reg'd 2] → [Register/Edit].
Press [Display Name] → enter the display name → press [OK].
Press [Attribute Name] → enter the attribute name → press [OK].
Press [OK] → [Close].
Select the attribute to edit → press [Register/Edit].
You can only edit the two search attributes displayed as 'Not Registered' by default. You cannot edit the name, e-mail, fax, organization, and organization unit attributes.
Press [Display Name].
Enter a name to display → press [OK].
Select the search attribute to delete → press [Delete].
You can only delete the two search attributes displayed as 'Not Registered' by default. You cannot delete the name, e-mail, fax, organization, and organization unit attributes.
Press [Yes] → [Close].
4.
Press [Close].
» Settings/Registration » Set Destination » Registering/Editing LDAP Search Attributes
08KE-0H5
