Top » Web Access » Customizing Settings » Restricting the Display Screen
08KE-19U
You can specify various settings for the display screen, such as the format of the screen and whether to display images.
Press [Function Settings] → [Web Access] → [Settings].
Press [View Settings].
4.
Specify each setting.
Select [On] or [Off] for each setting → press [OK].
If the desired setting is not displayed, press or to scroll to the desired setting.
[Show Images]:
Select whether to display images within the Web page.
[Show Animated GIF Images]:
Select whether to display animated GIFs.
[Enable Table]:
Select whether to display tables.
[Fit Web Page Into Screen Size]:
Select whether to display the content so that it fits within the width of the screen.
[Use JavaScript]:
Select whether to use JavaScript.
[Use Word Wrap]:
Select whether to use the word wrap function.
[Use Japanese Hyphenation]:
Select whether to use the Japanese word wrap function.
[Format]:
Select [Std CSS only], [Std CSS + Style Attribute], or [Std CSS + Style Attribute + External Imported CSS].
[Standard CSS]:
Select [CSS1], [CSS2], or [CSS3].
[Show Flash Contents]:
Select whether to display Flash content.
[Flash Animation Frame Interval]:
Select the display interval for the Flash animation frames.
If you want to specify the settings for [Show Images], [Show Animated GIF Images], [Enable Table], [Fit Web Page Into Screen Size], [Use JavaScript], [Use Word Wrap], [Use Japanese Hyphenation], and [Show Flash Contents]:
If you want to specify the settings for [Format]:
If you want to specify the settings for [Standard CSS]:
If you want to specify the settings for [Flash Animation Frame Interval]:
Specify the desired settings → press [OK].
Press [Format] → select the desired format → press [OK].
Press [Standard CSS] → select the type of Standard CSS → press [OK].
Press [Flash Animation Frame Interval] → select the flash animation frame interval → press [OK].
[Short]:
The flash animation is smooth.
[Medium]:
The flash animation frame display interval is between that of [Short] and [Long].
[Long]:
The flash animation is somewhat grainy.
If [Flash Animation Frame Interval] is set to 'Short', other operations, such as printing, may become slow.
The default settings are:
[Show Images]: On
[Show Animated GIF Images]: On
[Enable Table]: On
[Fit Web Page Into Screen Size]: Off
[Use JavaScript]: On
[Use Word Wrap]: Off
[Use Japanese Hyphenation]: Off
[Format]: Std CSS + Style Attribute + External Imported CSS
[Standard CSS]: CSS1
[Show Flash Contents]: On
[Flash Animation Frame Interval]: Medium
