Category Top
Overview of This Function
Overview of Login Services
Login Screens
SSO-H (Single Sign-On H)
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Menu for Administrators
Registering/Editing User Data for LDAP Server Authentication
Setting the SSO-H
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Other Trouble
Top » MEAP » Managing Applications » Starting/Stopping Applications
08KE-1YF
Starting Applications
Click [MEAP Application Management].
Application Name
Displays the name of the application.
Installed on
Displays the date on which the application was installed.
Status
Displays the status of the application.
License
Displays the license status of the application.
Resource Information
Displays the resources being used by the applications.
The types of application statuses are described below.
Message
Status
Installed
Application has been installed but not started, or the application has not been restarted after stopping the application and then restarting the machine.
Started
Application is running.
Stopped
Application is stopped.
Starting
Application is starting up.
Stopping
Application is closing down.
The types of license statuses are described below.
Message
Status
Installed
An effective license file has been installed.
Not Installed
License file is disabled.
Excess
Expiration date and the types of counters set for the installed license file, and any counter value(s) exceeding the upper limit of the license file.
Invalid
Installed license file has exceeded its expiration date. Alternatively, current counter value has exceeded the upper limit of the license file.
(When a license file is set to many types of counters, it will expire when any counter exceeds the upper limit.)
Resource Information displays the resources being used by all applications.
Description
Timing of Update
Storage
Amount of hard disk space being used. Shown in kilobytes (KB).
When installing/uninstalling applications.
Memory
Amount of memory being used. Shown in kilobytes (KB).
When starting/stopping applications.
Threads
Number of threads.
Sockets
Number of sockets.
File Descriptors
Number of file descriptors.
Select the application you want to start → click [Start].
You cannot start applications whose required license file has not been installed.
When the resources required for memory, threads, sockets, or file descriptors has run out, the application will not start, even if you click [Start].
To update an application, you must close the application you want to update.
Select the application you want to stop → click [Stop].
If you start/stop an application, you may need to restart the computer to activate the driver settings of USB devices. Follow the instructions on the screen and restart the computer.
