Category Top
Overview of This Function
Overview of Login Services
Login Screens
SSO-H (Single Sign-On H)
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Menu for Administrators
Registering/Editing User Data for LDAP Server Authentication
Setting the SSO-H
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Other Trouble
Top » MEAP » Before Starting SMS (Preparations) » Specifying the SSL Encrypted Communication Settings
08KE-1Y5
SMS uses SSL encrypted communication. To use SMS, you need to set the key pair and server certificate as the default key in advance. A preinstalled key pair and server certificate are registered in the machine.
If you try to access SMS without the default key set, 'HTTP 500 Internal Server Error' is displayed and login fails.
By setting the default key, SMS will always use encrypted SSL communications, regardless of whether [Use SSL] in [MEAP Settings] in [Management Settings] (Settings/Registration) is set to 'On' or 'Off'.
Press [Preferences] → [Network] → [TCP/IP Settings].
Press [SSL Settings] for [TCP/IP Settings] → [Key and Certificate].
4.
Select 'Default Key' (preinstalled key pair and server certificate) → press [Set as the Default Key].
5.
Press [Yes].
6.
Press [OK] → [OK].
For instructions on creating the key pair and self-signed server certificate required for SSL encrypted communication using the control panel of the machine, see "Key Pair and Server Certificate Settings for Encrypted SSL Communication" (Security).
For instructions on setting the key pair used for encrypted SSL communication, see "Setting the Key Pair Used With SSL Encrypted Communications" (Network).
