Category Top
Overview of This Function
Overview of Login Services
Login Screens
SSO-H (Single Sign-On H)
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Menu for Administrators
Registering/Editing User Data for LDAP Server Authentication
Setting the SSO-H
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Other Trouble
Top » MEAP » Before Starting SMS (Preparations)
08KE-1Y4
Before an administrator logs in to SMS, they should start the machine and follow the procedure below:
Specify the Network Settings
Specify the settings under [Network] in [Preferences] (Settings/Registration) and find out the machine's IP address. (See "Network.")
Specify the SSL Encrypted Communication Settings
SMS always uses SSL encrypted communication. If the default key for SSL is not set in advance, you cannot log in to SMS.
Enable Access to the Machine from the Web Browser
Set [Use HTTP] to 'On' in [TCP/IP Settings] in [Network] in [Preferences] (Settings/Registration). If it is not set to 'On', you cannot access the machine from the Web browser. For more information, see "Settings Common to TCP/IPv4 and TCP/IPv6."
By setting [Use HTTP] to 'On', you can open a necessary port. However, it is recommended that it is set to 'Off', if a port is not used. If you leave the port open, an unauthorized user may access the machine.
