When the Inner 2/3 Hole Puncher-A1 Is Attached
If there is paper in the output tray, remove the output paper before proceeding with this procedure.
Follow the instructions in "Main Unit" to remove any jammed paper.
Open the front cover of the finisher.
Remove any jammed paper protruding from the output tray.
4.
Remove any paper jammed inside the inner finisher.
1. Grip the lever, and pull the finisher away from the main unit.
2. Press down and hold the inner guide, and remove any jammed paper.
3. Return the finisher to its original position.
CAUTION
When returning the finisher to its original position, be careful not to get your fingers caught, as this may result in personal injury.
5.
Close the front cover of the finisher.
CAUTION
When closing the front cover, be careful not to get your fingers caught, as this may result in personal injury.
6.
Follow the instructions on the screen.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
» Problem Solving » Clearing Paper Jams » Inner Finisher-D1 (Optional) » When the Inner 2/3 Hole Puncher-A1 Is Attached
0CYL-0J2
