Category
Top » Print » Bar Code Printing » Introduction
Category Top
Printing Functions
[Page Setup] Sheet
[Finishing] Sheet
[Paper Source] Sheet
[Quality] Sheet
Common Functions
[Device Settings] Sheet
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided Printing and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Booklet Printing
Using [Presets] for Printing
Printing Flow With This Machine
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Paper Output
Print Quality
Layout
Auto Continue
Secure Print Delete Time
Timeout
Print After Completing RIP
Booklet
Saddle Stitch
Creep Correction
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Initialize
UFR II Settings
Halftones
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Symbol Set
Custom Paper
Unit of Measure
X dimension
Y dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
PS Settings
Job Timeout
Print PS Errors
Halftones
Grayscale Conversion
Dot Gain Adjustment
Imaging Settings
Image Orientation
Zoom
Print Position
Show Warnings
Enlarge Print Area
Halftones
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Halftones
Dot Gain Adjustment
XPS Settings
Halftones
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Collapse all|Expand all
Introduction
Overview of Bar Codes
Bar code technology provides an easy, inexpensive, and highly accurate means of data entry and storage for computerized information management systems.
Item identification information (e.g., inventory control, work-in-progress tracking, distribution tracking, and other material management) is the most common type of data stored in bar code systems.
1D Bar Codes
Most conventional bar code systems with only one-dimensional encoding, such as UPC (Universal Product Code), are called "1D Bar Codes." 1D Bar Codes consist of a single row of bars, and are best-suited to lower capacity applications, such as serial numbers.
2D Bar Codes
More complex high-density, two-dimensional bar codes, such as Data Matrix, are called "2D Bar Codes." In this format, data is encoded in both the horizontal and vertical dimensions. Some 2D bar codes can encode up to 12 KB of data, with features like data compression, macro bar codes, encryption, and error correction algorithms.
Product Features
This product supports more than 50 bar code formats (symbologies), as well as the EURO symbol (the European currency symbol), safety symbols, electronic, and manufacturing symbols. It also features the FreeScape system, which enables the host computer to use PCL, even if it cannot send binary data to a printer.
The optional product is required to use this function. For information on the optional product, see "Optional Products Required for Each Function."
