Category
Top » How to Use This Manual » How to Use This Manual (e-Manual) » Search Method
Category Top
Manuals for the Machine
System Requirements
Installing the e-Manual
Uninstalling the e-Manual
e-Manual Menu
e-Manual Topics
Search Method
Operations and Terms Used in This Manual (e-Manual)
Collapse all|Expand all
Search Method
1
Enter keyword(s) here
Enter a keyword in the entry field which is located on the upper right of the "Top" or "Topic page," and then click  to display the search dialog box.
You can also search by entering a keyword in the displayed dialog box.
In addition, you can refine the search results by entering two or more keywords using the AND search. When entering keywords, enter a space between the keywords.
Example: Toner Message (if you want to display pages which include words, "Toner" and "Message")
2
[Show search scope]
If you want to specify a search scope, click here, and then select the check box for the category which you want to search.
3
Search result
The search results for a keyword are displayed.
If the search results are more than 10 results, you can see the other results by clicking [« Prev], [Next »] or the number which is located below the result.
