Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
You can register/edit/delete user-defined text for page numbers and watermarks. It is useful if you always use the same text or watermark for Secure Watermark. For information on the Secure Watermark mode, see "Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)."
Press [Function Settings] → [Common] → [Print Settings].
Press [Register Characters for Page No./Watermark].
To register text:
To edit text:
To delete text:
To register text:
Press [Register] → enter the text → press [OK].
To edit text:
Select the text to edit → press [Edit].
Enter new text as necessary → press [OK].
To delete text:
Select the text to delete → press [Delete].
Press [Yes].
4.
Press [Close].
You can register up to 30 user-defined text strings for watermarks and page numbers.
For instructions on entering characters, see "Entering Characters from the Touch Panel Display."
» Settings/Registration » Function Settings » Common » Print Settings » Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
0UKW-05U
