Registering Paper Frequently Used in the Multi-Purpose Tray
You can register paper frequently used in the multi-purpose tray in a button to easily set the paper to use.
The registered button is displayed when [Favorite Paper] is selected in [Always Specify] in [Multi-Purpose Tray Defaults] in [Preferences] (Settings/Registration).
Press
![](./images/book_images/b_in_Add.jpg)
Press [Preferences] → [Paper Settings] → [Register Favorite Paper (Multi-Purpose Tray)].
Select the button to register → press [Register/Edit].
If you want to change the name of a button, select the button to change → press [Rename] → enter the new name.
4.
Select a paper type to register.
If you want to select a standard paper size:
Select the desired paper size → press [Next].
To select an A or B series paper size, press [A/B Size].
Select the desired paper type → press [OK].
If you want to select a free paper size:
Press [Free Size] → [Next].
If you want to select a custom paper size:
Press [Custom Size].
Press [X] and [Y] → enter each value → press [OK].
You can also select a size key ([S1] to [S4]) containing a stored paper size setting, instead of entering values.
Press [OK].
If you want to select an envelope type:
Press [Envelope].
Select the orientation and type of the envelope → press [OK].
Press [Next].
