You can store an e-mail address obtained by searching the directory listings on the network using LDAP (Lightweight Directory Access Protocol) servers.
You can also register e-mail addresses you obtain as I-fax addresses.
You may have to set up the LDAP servers beforehand, depending on the network environment. For more information on setting the LDAP servers, see "Registering an LDAP Server."
Press [Scan and Send] → [Address Book].
Press [Regist./Other].
Press [Register/Edit].
4.
Press [Register New Dest.].
5.
Select [Register from LDAP Server].
6.
Search for the desired destinations.
Perform the procedure in steps 5 to 10 of "Specifying Destinations Using the Address Book (LDAP Server)."
7.
Select the destination from the search results → press [Next].
You can select multiple destinations.
If you want to select the first 256 destinations, press [All (Max 256)].
If you press [Register E-Mail as I-Fax], the key lights to show that this setting is turned on, and the selected e-mail address can be registered as an I-fax destination. To register e-mail addresses as I-fax addresses, register one e-mail address at a time.
To cancel a selected destination, select the destination again.
8.
Register the selected destinations.
The information that can be obtained via the LDAP server consists of only names and e-mail addresses.
If you select only one destination:
If you select multiple destinations:
If you want to register the selected destination as an I-fax address:
Check the destination → press [OK].
Edit the contents of the destination as necessary.
If you are managing Address Book access numbers, perform the procedure in step 13 of "Registering an E-Mail Address."
Select the Address List in which to store the destinations → press [OK].
9.
Press [Close] → [OK].
» Scan and Send » Storing New Addresses » Registering an Address Obtained via an LDAP Server
0R9W-109
