Registering/Editing/Deleting Favorite Settings Buttons
You can register up to 18 combinations of favorite Send settings. You can also assign them names and comments for increased convenience. This feature is useful for storing frequently used Send settings.
Press
![](./images/book_images/b_in_Add.jpg)
(Settings/Registration).
To register/edit favorite settings buttons, you must specify the Send settings in advance.
Press [Function Settings] → [Send] → [Common Settings].
To register a favorite settings button:
Press [Register Favorite Settings] → [Next].
Select a button ([M1] to [M18]) to register settings → press [Next].
If <Show Comments> is set to 'On', the stored comments appear when you press a button on the Scan and Send screen.
Press [Name].
Enter a name → press [OK].
Press [Comment].
Enter a comment → press [OK].
Press [OK].
To edit a favorite settings button:
Press [Edit Favorite Settings].
Select a button to rename → press [Rename].
If you press [Check Content], the existing registered settings appear.
Press [Name].
Press [Comment].
Press [OK].
To overwrite registered settings, press [Register Favorite Settings] → select a button ([M1] to [M18]) to overwrite.
To delete a favorite settings button:
Select a button ([M1] to [M18]) to delete → press [Delete].
Confirm the settings to be deleted.
Press [Yes].
The name for the button is not deleted. To rename a button, press [Rename].
Press [Close].
Settings stored in favorite settings buttons are not deleted, even if the power is turned Off.
If an address included in a favorite settings button is deleted from the address book, it is also deleted from the settings registered in the favorite settings button.
