Scanning Originals with Correct Orientation
0C1Y-20Y
When scanning from the feeder, you can set Network ScanGear to display the document in its correct orientation on the computer monitor.
Switch the scanner online → load the originals into the feeder → start Color Network ScanGear or Network ScanGear from the application.
Set [Original Placement].
Using [Auto-adjust Orientation]:
Select [Auto-adjust Orientation].
During scanning, the orientation of the original is detected automatically, and the scanned image is rotated if necessary, so that it is displayed correctly on the computer screen.
Click [Orientation].
Select the orientation of the originals to be loaded into the feeder for [Feeding Direction].
For 2-sided originals, also set [Book Opening] to indicate the relation between the front and back sides of a 2-sided original.
Click [OK].
The window displayed may vary according to the operating system etc.
