Top » Web Access » Customizing Settings » Restricting the Display Screen
0C1Y-12C
You can specify various settings for the display screen, such as the format of the screen and whether to display images.
Press [Function Settings] → [Web Access] → [Settings].
Press [View Settings].
4.
Specify each setting.
Select [On] or [Off] for each setting → press [OK].
If the desired setting is not displayed, press or to scroll to the desired setting.
[Show Images]:
Select whether to display images within the Web page.
[Use Word Wrap]:
Select whether to use the word wrap function.
[Use JP Hyphenation]:
Select whether to use the Japanese word wrap function.
[Use JavaScript]:
Select whether to use JavaScript.
[Fit Page to Screen Size]:
Select whether to display the content so that it fits within the width of the screen.
[Enable Table]:
Select whether to display tables.
[Show Animated GIFs]:
Select whether to display animated GIFs.
[Format]:
Select [Std CSS only], [Std CSS + Style Attribute], or [Std CSS + Style Attribute + External Imported CSS].
[Standard CSS]:
Select [CSS1], [CSS2], or [CSS3].
If you want to specify the settings for [Format]:
If you want to specify the settings for [Standard CSS]:
Press [Format] → select the desired format → press [OK].
Press [Standard CSS] → select the type of Standard CSS → press [OK].
The default settings are:
[Show Images]: On
[Show Animated GIFs]: On
[Enable Table]: On
[Fit Page to Screen Size]: Off
[Use JavaScript]: On
[Use Word Wrap]: Off
[Use JP Hyphenation]: Off
[Format]: Std CSS + Style Attribute + External Imported CSS
[Standard CSS]: CSS1
