Top » Fax/I-Fax Inbox » Memory RX Inbox » Memory RX Inbox » Receiving Files Through Fax or I-Fax
0C1Y-11A
You can set whether to automatically print received Faxes and I-Faxes, or store them in the Memory RX Inbox.
Press [Fax/I-Fax Inbox].
Press [Memory RX Inbox].
Set <I-Fax Memory Lock>/<Fax Memory Lock>.
[On]:
Received files are stored in the Memory RX Inbox.
[Off]:
Received files are printed automatically.
If you have set [Memory Lock Start Time]/[Memory Lock End Time] in [Set Fax/I-Fax Inbox], the following is displayed. (See "Specifying the Fax/I-Fax Inbox Settings.")
When you select [On] for <Fax Memory Lock>/<I-Fax Memory Lock>: The end time for Memory Lock is displayed.
When you select [Off] for <Fax Memory Lock>/<I-Fax Memory Lock>: The start time for Memory Lock is displayed.
If you set <Fax Memory Lock> and/or <I-Fax Memory Lock> to 'Off', files received through the Fax/I-Fax function are automatically printed and deleted from the Memory RX Inbox.
4.
Press [Back] repeatedly until the Inbox Selection screen appears.
