Top » Scanner » WSD Scan » Scan Features of the WSD Scan
0C1Y-13X
This section describes how to use the scan features of the WSD Scan.
You can only perform a WSD scan under the following conditions:
Paper size:
LTR
Color mode:
Color
Resolutions:
300 dpi (fixed setting)
File format:
BMP, JPEG, PNG, TIFF
Press [Scanner] → [Online].
Set the scan function of the machine to online.
If [Scanner] is not displayed on the Main Menu screen, press [Show All].
After setting the machine to online, if the operation conflicts with other operations from scan driver, the earlier operation will be received.
Place your originals.
You cannot scan 2-sided originals even if you are using a feeder. Place 1-sided originals.
The available scanning size is LTR. For example, if you set LGL originals, only LTR size is scanned.
For instructions on placing originals, see "Placing Originals."
For Windows 7, click (Start) on a computer → [All Programs] → [Windows Fax and Scan]. For Windows 8, place the cursor on the top right (bottom right) of the desktop → select [Search] → enter [Windows Fax and Scan].
If [Windows Fax and Scan] is not displayed in Windows 7, follow the procedures below.
Click (Start) → [Control Panel] → [Programs] → [Turn Windows features on or off] → [Print and Document Services].
Clear the check box for [Windows Fax and Scan] → click [OK].
Restart the computer.
4.
Follow the same steps and select [Windows Fax and Scan] → click [OK].
For information on functions of the Windows operating system, see the manual provided with the operating system, or contact Microsoft.
4.
Click [Scan].
5.
Click [New Scan].
6.
Click [Change] → select this machine as a scanner → click [OK].
7.
Specify each setting.
[Profile]:
If you scan text originals, select [Document], or select [Photo] for scanning photos.
[Source]:
If you are using a feeder, select [Feeder (Scan one side)], or select [Flatbed] if you are using the platen glass.
[Paper size]:
Select LTR.
[Color format:]
[Color] is set.
[File type]:
Select from BMP, JPEG, PNG, and TIFF.
[Resolution]:
"300" is set.
8.
Click [Scan].
Scanned originals are displayed on the list.
Scanned files are stored in [Scanned Documents] folder in [Documents].
If you click [Preview], the scanned file is displayed, but it is not stored in a computer.
