Top » Flow of Settings » Operations Required Prior to Using the Machine
0C1Y-00S
This section describes the flow of operations and settings required prior to using the machine, for the functions you will use.
Confirm the Following Settings
Some functions of the machine require optional products and operations/settings.
Also, if you want to use functions that require license registration, see "Adding New Functions." See the flowcharts in this category for functions that require operations or settings.
For information on optional products, see "Optional Products/Software."
For information on the system requirements for using the following functions, see "Optional Equipment and System Requirements."
Using E-Mail/I-Fax for Scanning and sending (via e-mail/I-fax)
Sending Data for Scanning and sending (to a file server)
Function
Optional Product Required
License Registration
Operations Required
Copy
None
None
Scanning and Storing Files/Accessing Stored Files
Network
None*2
Memory Media*1
None*2
Scanning and Sending Files
E-Mail/I-Fax
None
Sending Files to File Servers
None
Fax
Sending Files from the Machine
None
Receiving Files on the Machine
None
None
Sending Files from a Computer via the Machine
None
Print
UFR II Print
None
PCL Print
None
Barcode Print
Barcode Printing Kit
Required
Direct Print
None*2
Remote UI
None
MEAP Management Function (SMS)
None
Registering/Updating Software (Delivery)
None
Registering/Updating Software (Manual)
None
Scanning
None
*1
The default setting for displaying Memory Media is 'Off'. To use memory media, press [Display Settings] in [Preferences] (Settings/Registration) → set <Memory Media> in [Store Location Display Settings] to 'On'.
*2
To print XPS files, the Direct Print Kit (for PDF/XPS) is required. Each optional product requires license registration.
