e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand all
Collapse all
Category Top
Operations Required Prior to Using the Machine
Logging In to the Machine as an Administrator
Sending E-Mail/I-Faxes
Sending Data to a File Server
Setting Up an Advanced Box on the Same Network
Using Memory Media
Directly Sending Faxes from the Machine
Sending Faxes from a Computer via the Machine
Printing from a Computer
Using the Machine as a Scanner
Managing the Machine from a Computer
Connecting the Machine to an External Network and Registering/Updating Software
Registering/Updating Software Without Connecting the Machine to an External Network
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Flow of Settings
0C1Y-014
The following operations and settings are required to use the machine as a scanner.
For information on the system requirements for installing the scanner driver, see
"System Requirements."
1. Connect the machine to the network.
Connecting to a Network
Interface Settings
2. Set the machine to use the TCP/IP network.
Protocol Settings
3. Install the software for specifying scanner settings (Network ScanGear) into the computer connected to the machine.
Before Using the Network Scanner
To Practical Workflows
Adding an Image Scanned via Network Scanner to a Document
Back to Top
