Registering/Editing One-Touch Buttons
Optional products are required to use the Fax function. For information on the optional products required to use the Fax function, see
"Optional Products Required for Each Function."
You cannot register a new destination in a group destination that is stored in a one-touch button. The destination must be registered in a one-touch button in advance.
Press
(Settings/Registration).
Press [Set Destination] → [Register One-Touch].
Select a one-touch button to register or change → press [Register/Edit].
If you know the one-touch button's three digit number, press
→ enter the three digit number of the desired one-touch button using
(numeric keys).
If you select a one-touch button already storing a destination, proceed to step 4.
The following icons are displayed to indicate the stored destination type for one-touch buttons in which a destination is already stored:
If you register multiple destinations as a group address in a one-touch button, the number of destinations registered in the group address appears.
4.
Select the type of destination to register.
Press [E-Mail].
Press [One-Touch Name].
Enter a name for the one-touch button → press [OK] → [Next].
Press [Fax].
Press [I-Fax].
Specify the I-fax mode, I-fax address, standard fields, send via server setting, and destination conditions in accordance with steps 8 to 13 of
"Registering an I-Fax Address."
Press [File].
Enter a name for the one-touch button → press [OK].
Press [Group].
Select a destination to store in the group address from [Add from One-Touch] → press [OK].
Only destinations that are already stored in one-touch buttons can be selected as part of a one-touch button group address.
(numeric keys).
If you select [Register from LDAP Server]:
Press [Register from LDAP Server].
Select the destination that you want to store in the one-touch button from the search results → press [Next].
You cannot select multiple destinations at the same time.
You can register the selected e-mail address as an I-fax address by pressing <Register E-Mail as I-Fax>. To register e-mail addresses as I-fax addresses, register one e-mail address at a time.
You can restrict the type of destinations displayed in the results list by selecting the desired type of destination from the drop-down list.
To cancel a selected destination, select the destination again.
If necessary, edit the contents of the destination.
The information that can be obtained via the LDAP server consists of only names, e-mail addresses, and fax numbers.
5.
Press [OK] → [Close].
If you set [Language/Keyboard Switch] to 'On' in [Preferences] (Settings/Registration), the host name and folder path of the file server destination may not be displayed correctly, and you may not be able to browse to them.
Destinations stored in one-touch buttons also appear in the Local Address Book.
You can register e-mail, fax numbers, I-fax, file server, and group destinations.
