Registering Shortcut Keys
You can create shortcuts to frequently used functions in [Options] in the Copy screen. You can also directly recall buttons registered in [Favorite Settings].
These shortcuts then appear on the Copy Basic Features screens.
Storing Shortcut Keys
Press [Function Settings] → [Copy] → [Register Options Shortcuts].
Select the button to register.
4.
Select the [Options] mode you want to assign as a shortcut → press [OK].
If you do not want to assign an option, select [Unassigned].
5.
Press [OK].
Assigning a Shortcut to a Registered [Favorite Settings] Button
4.
Press [Preset Fav. Settings] → select assigned Favorite Settings → press [OK].
To use this setting, you must first register Favorite Settings. (See "Assigning Shortcuts.")
5.
Press [OK].
» Settings/Registration » Function Settings » Copy » Registering Shortcut Keys
0C1Y-085
