For information on the optional products required to use this function, see "Optional Products Required for Each Function."
The Document Scan Lock mode does not guarantee restriction of unauthorized copying. You may not be able to restrict unauthorized copying or analyze tracking information, depending on the combination of settings and the output, such as a document with an image on the entire page.
Please note that Canon will not be held responsible for any damages caused by the use of the Document Scan Lock mode or the inability to use the Document Scan Lock mode.
Original
Copy A
(Secure Watermark Is Set) |
Copy B
(Copy of Copy A) |
Original
Copy C
([Print Vertically] Is Selected)
Copy D
(Copy of Copy C) |
Original
Copy/Print
Output
TL Code
The dots are printed in the background of output.
TL Code:
A TL code is a type of 2-dimensional bar code. A TL code is printed and by changing the arrangement of the dots, digital information is embedded on the output.
Original
Output with Embedded TL Code
(Scan Lock Information)
Jobs are restricted.
Copy/Print
Copy/Send/Store
Tracking Information with TL Code
(Original)
(Original)
Copy/Print
Copy
