Cause
The application file does not exist in the specified path, or the file path is incorrect.
Remedy
Specify the file path correctly.
Cause 1
The specified file is not a license switch file.
Remedy
Check that the specified file is a license switch file for initializing the password.
Cause 2
There is insufficient information for the specified file.
Remedy
The password cannot be initialized using the specified file. Confirm the contents of the file.
Cause
The specified file is not a switch license file for initializing the password.
Remedy
Specify a switch license file for initializing the password.
Cause
The specified license file has already been installed. License files that have been installed once cannot be installed again.
Remedy
Since the specified license file cannot be installed, specify another file.
Cause
Only a user with System Administrator (Administrator) privileges can log in to SMS with their user name and password. The user trying to log in cannot do so because they do not have administrator rights.
Remedy
Log in again with the user name and password of a user with System Administrator (Administrator) privileges.
Cause
Cannot log in for a specified period of time because another user is logged in or log out operations were not successfully performed.
Remedy
If another user is logged in, wait until the user has logged out. If no other user is logged in, wait until the lock is released.
Cause
An error has occurred for some reason. Refer to <Error Details> for details.
Remedy
If countermeasures for the error are still not clear from <Error Details>, contact your local authorized Canon dealer.
Cause
The application cannot be started because there are no redistributable modules included in the application.
Remedy
Contact the developer of the application.
Cause
The application cannot be started because it includes an applet, and the number of applets that can be started on the system would exceed the limit (nine applets) if the application was started.
Remedy
Stop an application running on the system which includes an applet, in order to reduce the number of applets running on the system, and then restart the application.
Cause
A license file is necessary to start the application (the license file has not been installed).
Remedy
Install the license file, and then restart the application.
Cause
The application cannot be started because system resources required to start the application are unable to be reserved.
Remedy
Stop another application, and then restart this application. It may be able to start this time.
Cause
The application cannot be uninstalled because the license file for the application still exists inside the machine.
Remedy
Uninstall the application after deleting the license on the [License Management] page.
Cause
The application cannot be started because the applet name the application is trying to register in the Applet Viewer Service differs from the applet name included in the application file.
Remedy
Since it is necessary to make corrections to the application, contact the developer of the application.
Cause
The application cannot be started because the user data of the User Preference Service and the application data of the Configuration Service are being deleted.
Remedy
Wait until the application setting information is deleted, and then restart the application.
Cause
Remedy
Cause
The application does not exist in the specified path, or the file path is incorrect.
Remedy
Cause
The license file does not exist in the specified path, or the file path is incorrect.
Remedy
Cause
A manifest does not exist for the file specified as the application.
Remedy
This application cannot be installed. Contact the developer of the application.
Cause
The contents of the file specified as an application file are incorrect, or information is missing.
Remedy
This application cannot be installed. Check the file. If there are no problems, contact your local authorized Canon dealer.
Cause
The contents of the file specified as a license file are incorrect, or information is missing.
Remedy
This license file cannot be installed. Check the file. If there are no problems, contact your local authorized Canon dealer.
Cause
The application cannot be installed because required information is not included in the application.
Remedy
Check the file. If there are no problems, contact your local authorized Canon dealer to see if there is any <Missing information>.
Cause 1
<Inaccurate information> in the application cannot be recognized as correct information.
Remedy
Contact your local authorized Canon dealer.
Cause 2
If the <Inaccurate information> is the MEAP Specifications, the MEAP specifications of the application and of the machine do not match.
Remedy
Cause 1
A valid code signature cannot be confirmed in the application.
Remedy
Perform the correct code signing for the application.
Cause 2
The file may have been modified.
Remedy
Cause
The application cannot be installed because the specified license file does not correspond to the specified application.
Remedy
Specify a license file which corresponds to the application.
Cause
You can install up to 19 applications. You are trying to install more applications than this number.
Remedy
You can install the new application by first uninstalling other applications (apart from system applications).
Cause
The license file cannot be installed because the license file ID information log will exceed the maximum number of entries.
Remedy
Cause
A license file which is already installed cannot be installed again. The specified license file has already been installed.
Remedy
The specified license file cannot be installed. Specify another license file.
Cause
You cannot install the application unless you specify a corresponding license file with the application.
Remedy
When specifying an application to install, also specify a corresponding license file.
Cause
The specified file is a system application. You cannot install it from this [Install] page.
Remedy
Install the application from the [Enhanced System Application Management] page.
Cause
An application and license file were specified, but the specified application does not require a license file.
Remedy
Install the application without specifying a license file.
Cause
In the license file, there is serial number information of machines in which the license file can be installed. The application you have specified cannot be installed, because your machine's serial number is not found in the serial number information in this license file.
Remedy
Specify a license file whose serial number information includes the serial number of your machine.
Cause
The application can only be installed in certain machine models. It cannot be installed in this machine.
Remedy
Specify an application which supports the machine.
Cause
The application cannot be installed because the display area of an applet included in the application exceeds the area that can be displayed on the panel of the machine.
Remedy
Install an application that includes only applets that fit within the maximum display area of the machine.
Cause
The specified file is a file for updating an application which is already installed. It is necessary to stop the application which is to be updated before updating.
Remedy
Stop the application that you want to update, and then perform the update again.
Cause
You have tried to upgrade an application which is already installed using a version of the same application with different license requirements.
Remedy
Maintain the same license conditions, and then try upgrading the application.
Cause
The application cannot be installed because there is not enough space left on the hard disk.
Remedy
Uninstall unnecessary applications to free up hard disk space.
Cause
The cancel button was pressed when the installation could not be canceled.
Remedy
Uninstall the application after disabling the license file and downloading it from the [License Management] page.
Cause
The installation could not be performed because the specified application does not correspond to the MEAP version of the machine.
Remedy
Cause
The installation could not be performed because the specified application is not an Enhanced System Application.
Remedy
Specify an application file for an Enhanced System Application.
Cause
The installation could not be completed because it conflicted with a system shutdown.
Remedy
Perform the installation again after the machine has restarted.
Cause
Remedy
Cause
Authentication information cannot be set because the entered Dept. ID does not exist, or the PIN is incorrect.
Remedy
Enter the correct Dept. ID and PIN registered for the machine.
Cause
The Department ID that was entered is a positive integer, but the registered Department ID is not a positive integer.
Remedy
Enter the correct password registered in the machine as the Department ID.
Cause
The Department ID is blank.
Remedy
Specify the Department ID.
Cause
The authentication information could not be set because an unspecified error occurred.
Remedy
Cause
The authentication information could not be deleted because an unspecified error occurred.
Remedy
Cause
The entered user name or password is incorrect, or an unspecified error occurred.
Remedy
Set the authentication information again after entering the correct user name and password.
Cause
Remedy
Cause
The specified file does not exist, or the file path is incorrect.
Remedy
Cause
The contents of the file are incorrect, or information is missing.
Remedy
This license file cannot be installed. Contact the developer of the application.
Cause
The installation could not be performed because the specified license file does not correspond to the application.
Remedy
Check whether the manifest file specified inside the license file is accurate.
Cause
Remedy
Cause
Remedy
Cause
The machine you are using is stated in the license file, but the specified license file could not be installed in your machine.
Remedy
Specify a license file that is compatible with your machine.
Cause
Remedy
from the [License Management] page. |
Cause
The license cannot be disabled because an application using the license is running.
Remedy
Close the application using the license before disabling the license.
Cause
Remedy
If countermeasures against the error are still not clear from the <Error Details>, contact the developer of the application.
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
The currently set login service, a login service that will be enabled after restarting the machine, and the Default Authentication login service cannot be uninstalled.
Remedy
Do not uninstall the currently set login service, a login service that will be enabled after restarting the machine, or the Default Authentication login service. To uninstall the currently set login service, uninstall it after restarting the machine.
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause 1
Remedy
Cause 2
Remedy
Cause
Remedy
Cause
The specified file is not a system application. This application cannot be installed from this [Enhanced System Application Management] page.
Remedy
Install from the [Install] page.
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause 1
<Inaccurate information> in the application file cannot be recognized as correct information.
Remedy
Cause 2
If the <Inaccurate information> is the MEAP Specifications, the MEAP Specifications of the application and of the machine do not match.
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Although the file is an update file for the login service that is currently set, it cannot update a login service that has already started.
Remedy
To install the update file for the login service, start another login service, and then install the update file.
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause 1
The contents of the file are incorrect. (The specified file is not a license file.)
Remedy
Check that the specified file is a license file.
Cause 2
Remedy
Cause
The specified file is not a switch license file that can be used to delete a license file ID log.
Remedy
Specify the path for a switch license file that can be used to delete the license file ID log.
Cause
The information for a license file installed on the machine cannot be displayed.
Remedy
Select another license file.
Cause
The password differs from the current password.
Remedy
Enter the current password correctly.
Cause
The new password is shorter than 8 characters or longer than 32 characters, or has characters that cannot be used for a password.
Remedy
Enter a new password 8 to 32 alphanumeric characters (a-z, A-Z, 0-9) in length.
Cause
The password cannot be changed because the new password and the password you entered for confirmation do not match.
Remedy
Enter the same password as the new password in the password confirmation field.
Cause
Remedy
Cause
The status of the application whose setting information is to be deleted is "Started," "Starting," or "Stopping."
Remedy
Click [Back] to return to the original page of the specified operation, and perform the deleting operation again after changing the status of the application to other than "Started," "Starting," or "Stopping."
Cause
The setting information could not be deleted because an unspecified error occurred.
Remedy
Click [Back] to return to the original page of the specified operation.
Cause
Application logs do not exist.
Remedy
Cause
The logs could not be downloaded because an unspecified error occurred.
Remedy
Cause
The logs could not be deleted because an unspecified error occurred.
Remedy
Cause
The application for specified operation does not exist in the machine.
Remedy
Cause
You cannot log in because the user name and password are incorrect.
Remedy
Confirm the user name and password. Enter the correct user name and password.
Cause 1
The LAN cable is not connected.
Remedy
Connect the LAN cable.
Cause 2
The primary/secondary DNS server settings in the machine are incorrect or not specified.
Remedy
Confirm the DNS server settings of the machine, and specify the correct values.
Cause 3
The DNS server specified in the machine is not started, or the service has been stopped.
Remedy
Follow the procedure below to confirm the settings.
Confirm the DNS server specified on the machine, and start the server if it has not been started.
Start the "Services" management tool on the DNS server.
Confirm the status of the DNS Server. If 'Started' is not displayed under <Status>, right-click [DNS Server] → select [Start].
Cause 4
The host record is not on the DNS server.
Remedy
Confirm that the host record exists on the DNS server.
Confirm that the forwarding settings are correct.
Cause 1
Remedy
Cause 2
The Active Directory server is not started.
Remedy
Start the Active Directory server.
Cause 3
The KDC (Key Distribution Center) service of Active Directory is stopped.
Remedy
Start the "Services" management tool on the Active Directory server.
Check whether the Active Directory server is operating normally.
Cause
The difference between the time set on the machine and the Active Directory server is greater than the allowed difference.
Remedy
Adjust the times of the machine and the Active Directory server so that they are within the allowed time difference.
Cause
Default settings were initialized because the port settings were changed.
Remedy
Restart the machine.
Cause
The site settings for Active Directory are incorrect.
Remedy
Check the settings for <Retrieve Site Information> and <Site Access Range> in <Access Modes in Sites>.
Cause
The card ID is incorrect.
Remedy
Use a control card with an assigned ID.
Cause
The key required for Domain Authentication has not been generated for Active Directory.
Remedy
Follow the procedure below to change the settings.
Start the Active Directory management tool, "Active Directory Users and Computers."
Right-click the user that failed to be authenticated.
Select [Reset Password] from the pop-up menu that is displayed.
Enter a new password in the [Reset Password] dialog box → click [OK].
Cause 1
The expiration date of the authenticated user account has expired.
Remedy
Select [Properties] from the pop-up menu that is displayed.
Select the [Account] tab → confirm the values in [Expiration Date] in [Account Expires].
If the expiration date has passed, extend the expiration date, or set it to 'None'.
Cause 2
The account of the authenticated user is disabled.
Remedy
Select the [Account] tab → confirm the [Disable Account] setting in [Account Options].
If [Disable Account] is selected, deselect it → click [OK].
Cause 1
The expiration date of the password for the authenticated user account has expired.
Remedy
Cause 2
The account of the authenticated user is set to 'User must change password at next logon'.
Remedy
Select the [Account] tab → confirm the [User must change password at next logon] setting in [Account Options].
If [User must change password at next logon] is selected, deselect it → click [OK].
Cause
When SSO-H is set as the login service, no Department ID is specified for the SSO-H user, even when Department ID Management is set to 'On'.
Remedy 1
To set Department ID Management to 'Off' and use the SSO-H login service, follow the procedures below:
Specify a login service other than SSO-H. For instructions on specifying login service settings, see "Login Service Selection."
Set Department ID Management to 'Off' using the touch panel display. For instructions on setting Department ID Management to 'Off', see "Specifying Department ID Management."
Turn OFF the main power of the machine, wait at least 10 seconds, and then turn ON the main power again. For instructions on turning ON and OFF the main power of the machine, see "Main Power and Energy Saver Key."
Remedy 2
To use the SSO-H login service with Department ID Management, follow the procedures below:
Remedy 2.1: Enable the Local Device Authentication administrator to login
Set the login service to SSO-H, and log in to SSO-H as the Local Device Authentication administrator. For instructions on specifying login service settings, see "Login Service Selection." For instructions on logging in to SSO-H as the Local Device Authentication administrator, see "Logging In to SSO-H."
Click [User Management] → click [Edit] for a user with System Administrator (Administrator) privileges.
Enter the Department ID, PIN, and Confirm items → click [Update]. Enter the registered System Manager ID and System PIN for the Department ID and PIN items respectively. If no System Manager ID is registered, enter a Department ID.
Set Department ID Management to 'On' using the touch panel display. For instructions on setting page limits for each Department ID, see "Specifying Department ID Management."
Remedy 2.2: Enable a general user to login.
Perform the procedures described in Remedy 2.1 to enable the Local Device Authentication administrator to login.
Press
(Settings/Registration) on the control panel.Press [Management Settings] → [User Management] → [Department ID Management].
Press [Register PIN] → [Register] → enter the Department ID and PIN to be assigned to the general user, using
- (numeric keys) → press [OK].Press [OK].
Log in to SSO-H as the Local Device Authentication administrator.
Click [User Management] → click [Edit] for the user to whom you want to assign the Department ID.
Enter the Department ID, PIN, and Confirm items → click [Update]. Enter the registered Department ID and PIN for the Department ID and PIN items respectively.
Cause
Even though the SSO-H login service is set, [Department ID Management] is set to 'On'.
Remedy
Change the current login service to a login application other than SSO-H.
Set [Department ID Management] to 'Off'. For instructions on setting [Department ID Management] to 'Off', see "Department ID Management."
Turn OFF the main power of the machine, wait at least 10 seconds, and then turn ON the main power again. For instructions on turning ON/OFF the machine, see "Main Power and Energy Saver Key."
Cause
The port number specified in the '_ldap' SRV record (part of the DNS information of the domain specified as the login destination) is incorrect.
Remedy
Start the DNS server management tool, "DNS."
Double-click [Forward Lookup Zones] → [domain specified as the login destination] → [_tcp] → right-click the '_ldap' SRV record.
Select the [Service Location (SRV)] tab → confirm the value in [Port Number].
If the port number is different from the port number of the LDAP service, enter the correct port number for the LDAP service → click [OK].
Cause
Since you failed the user authentication, the login service for the failed user is temporarily stopped.
Remedy
Wait a while, and then try to log in again.
Cause
Since you have exceeded the lockout threshold, the login service for the user is temporarily stopped.
Remedy
Cause
The user name or password settings in the LDAP server information is incorrect.
Remedy
Specify the user name or password again so that it matches the settings specified on the LDAP server side. For instructions on how to specify the settings, see "Registering/Editing LDAP Server Information."
Cause
Anonymous access is not allowed on the LDAP server.
Remedy
See "Registering/Editing LDAP Server Information" to select [Use authentication information] check box and specify the user name or password again so that it matches the settings on the LDAP server side.
Cause
The startup of the user preferences service (one of the MEAP system service) is not complete.
Remedy
Cause
The password entered in [Old Password] is incorrect.
Remedy
Confirm the password → enter the correct password.
