Cause
You tried to register more than the maximum number of Personal buttons/Shared buttons that can be registered.
Remedy
Delete any unnecessary buttons, and try registering again. (See "Editing a Personal Button/Shared Button.")
Cause
You tried to use the Personal button/Shared button imported from another imageRUNNER ADVANCE series machine that contains functions not supported by the machine.
Remedy
Create a Personal button/Shared button using the functions that are supported by your machine.
Cause
You tried to recall the settings registered in the Personal button/Shared button while the machine is processing another job.
Remedy
Wait a while, and try using the Personal button/Shared button again.
Cause
You tried to recall a button for a function that is stopped.
Remedy
Make the function that is stopped available for use, and try using the button again.
Cause
Registration of Personal buttons/Shared buttons is restricted.
Remedy
Log in as the administrator to register a button
Cause
Registration of Shared buttons is restricted.
Remedy
Cause
You tried to log in with a user name that does not have privileges.
Remedy
Try to log in with a user name that has privileges.
Cause
You tried to register more than the maximum number of Personal buttons/Shared buttons that can be registered when starting an import operation.
Remedy
Delete any unnecessary buttons, and try importing again.
Cause
Other user is using the device.
Remedy
Wait a while, and try again.
Cause
You specified a file different from the Quick Menu file when importing.
Remedy
Specify the correct file, and try importing again.
Cause
You imported a file containing buttons for functions that are not supported by your machine.
Remedy
Check the function status of your machine.
