Confidential Fax Inbox RX Report
This report is used to check whether documents have been successfully received in Confidential Fax Inboxes.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Reports can be printed only if 11" x 17", LGL, LTR, or LTRR (plain, recycled, thin, or color) is loaded in a paper source whose settings in [Other] in [Paper Drawer Auto Selection On/Off] in [Function Settings] (Settings/Registration) are set to 'On'. However, if [Consider Paper Type] for [Copy] is set to 'On' in [Paper Drawer Auto Selection On/Off], you cannot print from a paper source with color paper specified. (See "Enabling Paper Drawer Auto Selection.")
Press [Function Settings] → [Receive/Forward] → [Fax Settings].
Press [Confidential Fax Inbox RX Report].
4.
Press [On] → [OK].
Press [Off] if you do not want to print it.
For an example of a Fax RX Report, see "CONFIDENTIAL FAX INBOX RX REPORT."
» Settings/Registration » Function Settings » Receive/Forward » Specifying the Fax Settings » Confidential Fax Inbox RX Report
08KY-0E4
