Enabling ECM Reception
You can receive incoming documents using the Error Correction Mode (ECM).
Using ECM reduces the effect of system and line errors on documents that occur during sending or receiving.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
If you want to transmit using ECM, it is necessary that ECM Transmission be set in both the destination machine and this machine. This function does not operate unless ECM is set in both machines.)
Press [Function Settings] → [Receive/Forward] → [Fax Settings].
Press [ECM RX].
4.
Press [On] → [OK].
Select [Off] if you do not want to perform ECM reception.
Even when you set ECM, errors can sometimes occur due to a poor telephone line connection.
If there is trouble with the line, it will take more time to receive the documents.
» Settings/Registration » Function Settings » Receive/Forward » Specifying the Fax Settings » Enabling ECM Reception
08KY-0E2
