You can use this mode if the Super G3 2nd Line Fax Board is added to the Super G3 FAX Board.
[Priority TX]:
The line specified in [Priority TX] is selected to send if the line is not in use.
[Prohibit TX]:
The line specified in [Prohibit TX] is restricted. (The specified line is used only for receiving.)
You cannot set both [Priority TX] and [Prohibit TX] for the same line.
Set one single line for [Priority TX]. You cannot set all lines to [Prohibit TX].
Even if you set to prohibit using Line1 for sending documents, Line1 is still used for fax information services.
If you select another line in [Options], that setting takes priority.
