Enabling Auto Orientation
Setting this mode enables the machine to use information such as the size of the original and the zoom ratio to determine the most suitable orientation for the specified paper size. The machine then automatically rotates the image if necessary.
This mode can be set when the Copy function is available for use. For information on the optional products required to use the Copy function, see
"Optional Products Required for Each Function."
Press
![](./images/book_images/b_in_Add.jpg)
(Settings/Registration).
Press [Function Settings] → [Copy] → [Auto Orientation].
Press [On] → [OK].
Select [Off] if you do not want to enable auto orientation.
If you are enlarging LTR or STMT originals are enlarged onto 11" x 17" or LGL copy paper, Auto Orientation is not performed even if you select [On].
Only the images of standard size originals up to LTR size can be rotated when the copy ratio is set to 100%.
If you set Automatic Paper Selection and the most suitable paper size is not available, the paper source that is loaded with paper of the same size is displayed as optimal, even if the orientation is different.
